It is currently Fri Jun 20, 2025 3:13 am
PostPosted: Thu Jan 12, 2006 3:16 pm
I have a Sears 3 wheel 10" bench top band saw. Don't like the blades Sears sells. (these are 56 7/8", I think)
Anyone have any custom made or know of other vendors?
I need an alternative....Terry Stowell38729.9713657407
PostPosted: Thu Jan 12, 2006 4:24 pm
Try Grizzly.com
john hall
PostPosted: Thu Jan 12, 2006 4:38 pm
For the band saw, I use a special blade that works great for very smooth cuts. I bought it to make very accurate smooth cuts for the homemade rosette ropes I'm making. Here are the specs: 10tpi, 1/2" width, .025" thick, .029" kerf. The source is www.hastingssaws.com. It is a special item and the blade is custom made and sold by the foot. It cost around $12 for an 80" blade which is a great deal. Call them and give them the above specs and they will get you what you need.John Elshaw38730.0281712963
PostPosted: Thu Jan 12, 2006 6:33 pm
I tried replacing a sears blade once and found that only sears makes them. You will probably have to have one made.
PostPosted: Thu Jan 12, 2006 11:23 pm
Woodcraft has their own in-house brand that they'll weld them to whatever length you want. You can get Timberwolf blades custom made, too, at Suffolk Machinery. I don't think it's that much more expensive to have them made than to buy them off the shelf.
PostPosted: Fri Jan 13, 2006 12:53 am
grizzly does have a 58 1/8 blade . There are so many available , you need to look at what you are doing. I use mybandsaw for rought cutting. So I use a coarser tooth but for close work a 6 tooth raker is fine. This lets a little sanding work but then you want to sand some anyway
john
